AiM PDM32 wake / sleep mode
EFI Wiring Fundamentals
I am building a '72 Datsun 240z as a restomod street car. I have added many modern electrical comforts (EPS, vintage air, stereo, power locks, windows, hatch pop, etc) and I have chosen to use the AiM PDM32 and EPM32, which allows me to eliminate all relays and greatly simplify the wiring. This is important because the space behind the dash for electrical components has become very tight.
I'm running into one big annoyance with this equipment though- With the key off, the PDM is completely inactive. There are two digital input channels (11 & 12) that can be used to "wake" the pdm without turning on the ignition, but waking from sleep takes 3-5 seconds. This has made it challenging to get the following battery direct power features to work:
- Key fob lock / unlock
- Key fob hatch pop
- Horn
- Key off fan control (keep the fan running to reduce heat soak after a drive)
The hazards and brake lights are simple enough and low current such that I don't mind powering them directly from the battery with a traditional fuse. But for the things above that need polarity reversing (door locks) I want to use the half bridges in the EPM. The horn and hatch pop solenoid are relatively high current draw and the last thing I want to do is throw more relays at it- I want to run as much through the PDM as possible. Can anyone with AiM experience recommend a tidy solution to automatically wake the PDM before a key fob command or delay sleep mode for fan operation?
Hey Bryan,
First up, sounds like my kind of build. I’ve done something very similar to my dad’s 260Z.
The fan overrun is fairly simple, as the PDM will already be awake. You can use an output of the PDM to feed input 11 or 12, which are the inputs that keep the PDM awake with the key off. This can be set up essentially as an overrun timer. You could set it to turn off at a certain coolant temp or keep it as a simple delay timer. If you go with coolant temp, I’d still add a max run time so a dodgy sensor can’t keep it awake and flatten the battery.
The key fob actions are the tricky ones, as the fob signal will generally be way too short to wake the PDM and then trigger the lock/unlock. Some fob modules will let you program and extend the trigger output, which may buy enough time to use that signal to wake the PDM and still trigger the locks. Just use the other wake input for this, so the fob and fan aren’t feeding each other. The obvious downside to this will be a 2-3 second delay on all fob actions. What fob system are you using?
As for the horn, it’s similar to the key fob. If you want instant response, you’d need to anticipate using the horn, which isn’t easy (or possible) for mere mortals. Otherwise you’d need the horn switch to provide a 12V signal to the PDM and hold it until the PDM wakes and triggers the horn output. That may not be a huge issue though, as the times you really need an instant horn are while you’re driving and the PDM is already awake.
The simplest option for the horn and key fob would be to feed input 11 or 12 with a constant 12V, keeping the PDM always awake. The obvious downside is the constant draw. With the ignition off, the AiM can be set up to only power the few components you need when they're switched, but you’ll still have the draw of the PDM itself, and it’s fully awake rather than in a low-power standby. I don’t have any numbers on this, but depending on the size of your battery and the current draw, it could be fine for 2 weeks, or only last a day or 2 before the battery goes flat. If you try it, it’s worth measuring the draw at the battery with the key off so you know where you stand. A few quick numbers, current draw of the PDM and your batteries amp hour rating and you have an idea how long it will last.
I don’t have direct experience with the AiM PDM32, so there may be a direct AiM solution I’m unaware of, but this is generally how I’d approach it.
The fan override makes sense, I didn't think about using one of the output channels to feed one of the input channels.
The key fob I'm using is a Dakota Digital CMD10k. Its a good unit but it does require an external polarity reversing circuit for the locks, and it doesn't output enough current to drive my hatch popper.
I could try keeping the PDM active full time- I haven't found any documentation on how much the PDM itself would draw in its wake state. I'm hesitant to power everything up and measure the parasitic draw because I'm still in the harness building stage and if that solution turns out to be inadequate I'll have to rebuild part of the wiring harness down the road.
The other idea I had was to abandon the CMD10k and find a fob that has a proximity output. That way when the driver gets within a certain distance of the car, the remote module would send a signal to PDM channel 11, waking the PDM in anticipation of a button press on the fob. I believe units like this exist but I don't have any personal experience with one- if anyone reading this does have experience with one they could recommend or tell me if this is possible/a good idea, that would be very helpful.
