Depinning Tool Kit
EFI Wiring Fundamentals
Good evening,
In putting together my tooling for loom construction and modification I have been stumped at finding a high quality pin removal kit.
If anyone could recommend a good quality and comprehensive kit or retailer I would appreciate it.
Thank you.
Hey Ryan, it may require some consideration as to what connectors you're primarily working with (deutsch, milspec, weatherpack, etc) but there are a few good options out there that I've used and am aware of.
Deutsch connector pin extraction set - HD-RMT-K or HD-RMT-DK (deluxe set) available @ buydeutsch.com
Milspec wiring connector pin removal/insertion tool - various tools per wire size sold separately @ milspecwiring.com
Weatherpack automotive connector pin release tool- Delphi/Packard extraction tool 12014012 available all across the web
Hope this helps or that someone may correct me if there is knowledge on a better all-inclusive type kit.
Predominately I am working on Hondas and Nissans.
There isn't really an all inclusive kit that works well to my knowledge rather specific tools for a specific range of connectors.
It's worth mentioning that the readily available, cheap multi-piece, OEM terminal removal tools don't tend to do the best job.
Something along the lines of these should see you right https://www.rcautoworks.com/products/honda-depin-tools-free-shipping
