Shielded wire in harness
EFI Wiring Fundamentals
Hi
Is there any preference where in the concentric wire harness to place the shielded wires for crank and cam sensors?
In the center or on the outer layers?
Thanks
I typically use the shielded wires as the centre core of a concentric twisted harness as it's a little harder to incorporate these in an outer layer neatly.
Hi, Thank you for the info. I was planning on doing the same
