Videos won't play
EFI Wiring Fundamentals
When I bring up the module and go to the video I want to watch it brings up the video but when I hit the play button it does nothing
They do for me.
OK, while that answer isn't much help, you haven't given anything for us to work on, have you?
First thing may be to do a quick search of the forums, as this has been raised several times before and you may find a solution there.
Failing, or in parallel, to that, if you post the device(s) you're trying to use, the player/app', the OS, etc, it would help narrow down your issue - the vid's are informative and cover points you may have forgotten or been unaware of, so if we can get you sorted, all good.
