KFMIRL KFMIOP Spreadsheet
Ethanol & Flex Fuel Tuning
I noticed when looking at the formulas in the spreadsheet from the worked example (I have it attached here too) that if you go into the KFMIOP table in the high load areas and you look at the formula it differs from the lower load/rpm areas.
What i mean is, in the lower load areas, the KFMIOP map references the exact same cell from KFMIRL above, but in the higher load/rpm areas when you look at the formula it actually is referencing one cell above from the KFMIRL table, not the corresponding cell.
Is this an error or is there a reason for this?
Chris
That looks to be an error. Thanks for pointing it out, I'll address it shortly.
Hello!
I don't see where the error is! KFMIRL is a 16 x 12 map whereas KFMIOP is 16 x 11.
The sequence is the spreadsheet is correct.
