Chevrolet 6.2 stroker in jeep comanche
Good morning, I'm new to these forums, but I would appreciate some advice. I'm building a 6.2L engine from a Yukon Denali and would like to convert it to a 316 stroker, maybe a bit bigger. What do you recommend? I'll be using a TH350 transmission in a Jeep Comanche with a 3.07 gear ratio and 33-inch tires. I plan to use it for 100-yard sand drag racing. I currently have a modified 6.0L engine doing a 4.96-second 100-yard run.
