Help with RB25 Ecu Master emu classic
So I’ve just installed the emu classic to my rb25 s2 swapped s13
I’m not getting any spark and can’t figure out why.
Everything else seems to be working ie injectors, tps and all other sensors.
I can only think of it being a trigger issue, the cas shows sync when cranking however I’m not able to set the base timing as my timing light isn’t doing anything.
This has also confused me as all coilpacks have 12v+,Good earth and .1v from the signal wire when I perform the output test to the coils which I believe is in spec.
any help would be appreciated
Do you have spark when you use the output test to the coils?
The settings in your picture attached seems correct to me. You can confirm the trigger pattern using the scope function in the ECU.
Just to confirm, under cranking you have a tach' signal on the dash? If you do it's very unlikely to be a pickup/trigger issue but lie somewhere in the wiring and/or allocation/settings.
