Need help with a ford rocam engine
I need assistance i replaced the headgasket and I put in water left it over night water stayed exactly the same then I cranked the engine with out plugs water stayed no pushing out the water bottle then I put everything back trying to start it now water pushing out water bottle like when it had no compression it was okay now that there is compression it pushing water out
Head was in at engineering and they did everything so according to them it okay
New head bolts was used
Block was cleaned properly and checked
Head was torque
30 nm
60nm
Then 180 degree
