Piston Measurement
Hey Everyone,
This is my first time trying to take apart and rebuilding an engine.
It's also my first time using a Micrometer.
I'm helping my son with his 2007 Mazdaspeed 3, 2.3L engine.
I need help to understand if we have used the Micrometer correctly as our readings are higher than what the Engine Workshop Manual states.
Hopefully the photos I took are clear enough for you all to understand.
If our readings is correct why are the piston size bigger than what the manual said they're to be?
NB: the piston are OEM they have the Mazda logo printed on them.
My next step it to measure the the Piston to Cylinder clearance but need help before I move on. Hopefully the Dial Bore Gauge is easy to use.
I'm not sure as to why the photos are posted jumbled.
Open them as follows.
1, 01, 001
2, 02, 002
3, 03
4, 04, 004
