Smart coil voltage
Hi!
Has someone have experience, what is the highest voltage smartcoil like (for examble ) Bosch 0 221 604 800 can take in a dragrace application?
Is there any benefit of raising voltage? What are the symptoms, if I have too weak spark?
Methanol turbo dragbike.
Thanks
Jani
I have run those coils to 18V with a 1.35ms dwell. They draw 11A peak current at that dwell and voltage, you could increase the dwell out to 1.5ms before hitting the saturation point of the coil.
OK
Thanks Stephen!
Jani
