SR20DET ENGINE BALANCING WITH ATI SUPER DAMPER
Hello all,
I have bought an ATI SUPER DAMPER for my SR20 and going to get the engine balanced. I have noticed in the instructions it states zero balance units should not be on the crankshaft for balancing and to install it during engine assembly. I’m just wondering what’s the way the rotating assembly should be balanced. Do you put stock pulley on? Do you balancing it without any pulley? Do you just put the bolt and washer in the crank and with the flywheel and clutch cover?
Many thanks
Tom
