Can I find aftermarket ECU connector clips for Toyota Factory ECU?
Introduction to Engine Tuning
I have factory 1HD-FTE turbo diesel engine and a ECU, looking forward to build an EFI wiring harness for that setup. I was wondering is there a dtm or any sort of after market connector for the factory ECU? or I have to find a factory connector?
It can be tricky or sometimes impossible to source replacement ECU header plugs sadly. Unfortunately this isn't an ECU that I've dealt with so I'm not even sure what the header plug looks like. It might be worth checking with some ECU manufacturers that offer Toyota plug & play adaptors or ECUs and see if they can supply the header plug.
Check your chassis number up at partsouq.com and go to the electrical section and search the catalog
