EMU Black Trigger set up
Introduction to Engine Tuning
Hello.
I’d like to know how to set up the crank trigger on EMU Black.
My car’s engine is a 2L Ford Duratec inline-4.
The trigger has 36 teeth, with one missing.
When I checked the vehicle, it looked like the attached diagram.
The engine rotates clockwise in this diagram.
The attached image shows the state at the time of TDC.TDC is when the 9th tooth from the missing tooth is located at the crank angle sensor.
I’d like to know the values ​​I should enter in the following fields:
Trigger edge
First trigger tooth
Trigger angle
Cranking gap detection scale
Next edge rejection angle
Enable CAM sync tooth window
Input delay
I’d also like to know whether to check or uncheck the following:
Increase precision at high RPM
Enable scope
Ignition angle lock
