how to configure launch control using speed as disarming switch
i have some trouble configuring launch control using speed as disarming switch..what is the proper way to.do that..using links storm..tq
If you want to use ground speed to disarm the launch control, you can simply set up your rpm limit in the launch rpm table when the car is stationary. Anywhere else in the table should be set to your normal rpm limit.
If you're interested in a detailed explanation of launch control tuning, check out our Launch Control course here - https://www.hpacademy.com/courses/launch-control/ This course has a complete worked example using our 350Z on the Link G4+ software platform.
