electronic wastegate
MoTeC M1 Software Tutorial
hey guys
anyone here have experience with VAG electronic wastegates ?
I am installing an EFR 7163 turbo on mk7 R
I installed the wastegate from the original turbo but i am not able to hold boost
trying to figure out how to setup the wastegate
What are you using to control the wastegate? Are you running a standlone ECU or reflashing the OE ECU?
Hi
Stock boost system and stock ECU
reflashing the stock ecu
here's a wastegate vid (at the end i get an error as low boost and wastegate opens fully)
