Hi, I just joined and i need to know if there any webinars you can suggest that will help me with idle and fuel trim tuning with HP Tuners for a 2017 ZL1? This is my personal vehicle that i just had upgraded the cam and supercharger size. Example..I had watched the idle tuning webinar, but i dont see anywhere Idle Airflow(only RPM or TORQUE). Lot of the videos seem to be LS engines and not the newer LT and the settings are not visible in Editor.
Thanks
Hi Ben, yes we currently are mostly focussed on the LS and not the later Gen 5 torque based ECUs. What specific questions did you have and I'll see if I can help. It might help if you attach your calibration and if possible a log of your issue.
