Flyback diode selection
Practical TIG Welding
Discussion and questions related to the course Practical TIG Welding.
What are people using for flyback diodes on things such as thermofans. I'm not completely sure how to best select one, is it just a case of picking something with a sufficient amperage rating.
Good question, I'm not sure how/if this has been addressed in the guides, but I would suggest yes - the trick is knowing what that's going to be.
You'd need to select a diode that is rated to at least the current draw of the fan which should be provided by the manufacturer. Diodes also have a voltage rating which unsurprisingly needs to be able to handle the voltage of the system which is of course 14 volts. In this case a safety factor of 2 would be typical so something rated above 24 volts should suffice. The above would be suitable for a on/off operation but if you're planning to use PWM speed control then things can become much more complicated.
