Gravel/Wet tires where to messure?
Practical Standalone Tuning
Hi! I'm running an Suzuki Swift fwd in gravel rallys and tire pressure is something I would like to optimize. But when you are taking these measurements on the tyre you insert the tyre temp tool inside the tyre, but if I run these gravel tyres where would I insert it, between the "studs" or inside the groove? Since the studs is what is contacting the ground i assume that is where most of the heat will be generated but at the same time they will vary alot since they are so small. Here is a photo of what I'm refeering to. https://www.rallynuts.com/user/products/KUMR800R-2.jpg
Would i measure on the blocks themself or between the blocks?
Thanks!
Answered in another thread:
https://www.racecrafthq.com/forum/general-discussion/show/tyres
Matt
RaceCraft Team
