2015 WRX MAPDCCD inquirie
hey everyone, hope you all having a great day.
i have a 2015 wrx that I swapped a 2020 sti trans in it and I choose the MAPDCCD for my dif controller.
The install seem to be pretty easy if you know what you’re working with. And hopefully I can get a thread on how to install the MAPDCCD for the 2015+ WRX platform to make it easier for people who wants to do it their selves sense I didn’t find help online.
i got all of the main wires connected and i was able to get the RPM calibrated on the MAP software. Now the only thing left is a VSS signal, and I come to find out the 2015 wrx uses HALL EFFECT type for abs sensors and I can’t simply just tap into them and I also can’t tap into my cluster instrument connectors because that’s a CANBus signal.. so I contacted MAP and they sent me a circuit to overcome the issue and get a proper signal that MAPDCCD controller can read after adding a capacitor and a resistor for each wheel which is through their advanced/basic wheel Speed Processor which again requires 4 twisted pairs for each wheel. I have not installed it yet tho just because I can’t seem to find the right pin out for the VDC conector..
the one I have printed and the one I have on the car are similar in shape but has different layout for terminal numbers. I contacted Subaru dealership to try to help out if they have a different diagram for my car under vin number but I came back empty handed..
Now my questions are:
1: how can I read the VDC pins and locate them to my diagram? ( worst case scenario)
2: When wiring in the capacitor and the resistor, is my understanding correct ?
( Tap into signal wire then add a 1uF capacitor where positive is towards the VDC and negative towards the MAPDCCD controller then from the capacitor I tap in a 10k ohm resistor and connect the other end to the second twisted wire coming from MAPDCCD controller then tap that into the VDC ground wire )
Please correct me ( I know I’m wrong ) lol
I am attaching the VDC diag sheet with few of MAPDCCD sheets. Hopefully that help out
Thank you all in advance
