Currently working on MCP to connect OpenAi Codex to Fusion to create 3d printed items or drawings for modelling. Curious any else thinking or done this and had good results ? On side note I have done this for Haltech NSP and it will check config real time for you and let you know any problems.
** update Claude Code is way better , with a custom MCP you can build in fusion through natural language , huge unlock as you learn the product. I will add some screen shots so you can see as I go.
Not something I have tinkered with personally but have seen it being done with mixed success. Mostly success, but with varying quality. Pretty awesome and great you found Claude Code! There is a bit of back and forth as they jump here and there but for the moment Claude Code seems to be the best all round for this sort of project.
A few months later and how much deeper have you gotten?
Entire new level now I am building my own version of fusion 360 as well as using open source versions like SolidCraft: free, open-source parametric 3D CAD that are designed for an MCP server, I have been using AI now to create more complex drawings and get parts CNC machined or 3d printed from china. Here is an example now of a 13b rotary 8hp50 adapter I received this week from China end to end designed by OpenAI and Claude designing it in fusion 360 free edition. These STL took about 2 hours to create , the adapter need some verification work so add an extra 2 hours for that. But I have no idea how to use Cad other than your course so i can imagine a skilled person much faster. This has been heaps of fun I 3d print the parts and then send to china. What I like about it is it verifies the part is ok to machine in the desired metal and looks at tolerances and clearances. It also makes suggestions on how to optimize the print or cnc. One thing I have been using is Computer use in Openai codex this just takes over the mouse and builds for you, its a bit slower than modifying the json file directly but really cool to watch.
