Can someone help me Import WinDarab txt file in I2 pro
Professional Motorsport Data Analysis
Hi
I have a GT3 txt data export from bosch windarab ,I2 can import this format, but only dealers.
Thank you
That is not correct. Anyone can purchase the licence for converting a windarab text export into an i2 LD file.
Additional to this, there are several issues with your supplied file.
1. You have included x dist, which is not required as this is windarabs equivalent of corrected distance in i2
2. The most important one - and the most common issue. When this export was completed all channels was selected. The issue with this (and many Bosch logging configurations) is there can be many channels that do not have any data samples for the entirety of the log file. The issue with that, is when the text file is generated, channels with no value are not correctly aligned and the system does not know how to write a null value for that channel. What then occurs is misalignment of the data in relation to the channels. In your attached file, there is probably in excess of 200 channels that have no values. This leads to a lot of data misrepesentation (as shown in the attached screenshot)
To convert this to something useable, you would need to do one of the following items:
- Manually select all the data channels that have values in the export window
- populate a time graph in windarab with all the channels that have values, so that 'all channels in current measurement window' could be selected in the export channel view
Thanks for your advice, I will look for a dealer to buy the license and fix the above problems
