Wiring harness design application.
If I am posting this into the wrong thread then perhaps an admin can move it to where it needs to be...
I am sure that many of you guys that have tried to design a wiring harness have come up short on choices of applications that you are able to use and fit within your budget. That's what happened to me and is what drove me to spend a year writing an application from the ground up that is design specific to wiring harnesses.
The application has so many features I don't know where to start. It is full featured to say the least. The best part about this application is it's free for DIY use. The next best thing about it, it's open source.
You can check out some screen shots of the app and a brief overview of what it is able to do by clicking on the link at the bottom of this post.
I am still developing the application and I am hoping for a pre-release test version in the next few weeks. So keep an eye out for it.
https://github.com/HarnessDesigner/HarnessDesigner
You can make comments and suggestions using the link below.
https://github.com/HarnessDesigner/HarnessDesigner/discussions
Hopefully this will be the application you use to design your next wiring harness!!!
--Kevin
Very beautiful with the 3D renders. Big effort. It'll be amazing if it has a live parts library mapped to Mouser (or equivalent) part numbers. I know with PCB design in KiCAD, it's amazing that I can grab a Mouser part number, and the pull in the PCB pin layout and 3D model live from the site.
I've used https://www.harness.design/ a fair bit. Great to have another option.
@hardy_bm
The app goes well above and beyond anything you have seen...
The way the parts are stored in the database is using the manufacturers part number so you can easily locate a part on mouser using that number. Built into the application is also real time python scripting support, built in web browser that has tools available for inspecting incoming and outgoing data. This is purpose built for writing parts scrapers. The cool thing about it is you will be able to optionally build a scraper using AI where it will be able to utilize the network tools to build the scraper. That is something that you will have access to as well.
What I did not build into the app is pulling stock quantities from a distributor. I focused the app to target the actual manufacturers and not the distributors. I do plan on providing the ability to export the BOM as JSON or CSV so you can send it to a distributor for them to import and build a quote from. With the real time python scripting support you can write a script that can handle automatically doing that for you is you wanted to. I also started working on making the application extensible . This will allow plugins to be made to extend the application to add specific features that are not included and me be wanted.
There is also a ray trace renderer that is built in as well that can produce high quality snapshots of a harness, all the way up to 32K 32768x13824 (21:9) resolution. The ray tracer allows you to set these options
reflections
depth of field
samples
environment maps
shadows
softness of the shadows
background
ambient occlusion
ambient occlusion samples
ambient occlusion radius
ambient lighting intensity
adding additional light sources (position, intensity and color)
With wire to wire connectors there is no pin layouts available for the connectors. Those pin maps you see in KiCAD are also in 2D because you are working in a 2D editing environment. That is not the case with wire to wire connectors.
To solve this issue the first time a model is downloaded from a manufacturer a dialog will open up that allows the user to set the part orientation. Because the app has no knowledge of how the part is orientated the application needs to know what is "up" and what is "forward" for a part in order to present rotation angles in Euler (x, y, z) form without having free spinning issues (gimbal lock) during rotation. once that is done then another dialog opens up so the user is able to set the location of the cavities in a housing where the terminal pins will sit. I have tried to make the process of locating those caviti4es as painless as possible. The user selects the wire side openings and the pin side openings of the housing. The software will locate all surfaces that are on the same plane as the one selected. If there are no defined surfaces that would represent these locations the user is able to click on the surface where they would be and they can manually draw the locations onto the surface. This process only has to be done once for each downloaded model. I am planning on setting up a way that a user is able to submit the data for inclusion into the prebuilt database,. but that is going to be something added in the future.
