Hex editing
CANBus Communications Decoded
Relevant Module: Conclusion > Conclusion
Do you have any courses about hex editing?
I worked at chrysler dodge jeep dealerships for 20 year now have my own shop doing custom builds / hemi drivetrain swaps
Looking to deal with issues like removing air bag systems from the bus and vin mis match errors when using modules from different vehicles
Most of my donor cars are wrecked salvage vehicles, modules are often damaged
I have a wi tech cda6 engineering software
And an obdstar g3 both have hex editing
Also alpha obd
But dont know how to use them correctly
Is there any courses on this ?
Also looking into a hp tuners
Thanks in advance
I too am looking for similar information as to how to alter CAN bus messages, so I am going to follow your FORUM inquiry.
I have a 2017 Camaro engine, trans, dash and entire wiring harness installed in a gen 1 Camaro. I also want to remove CAN bus communications from the air bag system, antilock brakes, and other systems not being used in my build.
