Im in the process of engine a 2005 nissan caravan e25 diesel that came with a zd30 to the z20 from a 1989 e24 model. In this swap I want to retain my factory dashboard and key function. I have 6 devices total that need power and wires which are the alternator, carb, starter, water temp,oil pressure and ignition coil.
The dash requires the factory dieselecu to output but is there any way I can use the diesel harness to create a harness for the z20.
Any help and advice is greatly appreciated.
https://www.scribd.com/document/742675418/Nissan-E25
This is a service manual with the layout of the diesel harness if this can provide any insight.
