Internal Micrometre for bearing clearances
Has anyone used one of these for doing bearing clearances etc? Seems like it would be easier to get the actual value, than using telescopic gauges and an inside mic.
inside mic
https://www.machineryhouse.com.au/q135
Limits you to top of bore. But probably a good sanity check for changeover readings to the other internal guages.
It takes one more potential measuring error out of the equation, which is usually a good thing.
there are a huge range of designs available and, because I don't know the name, I'd stick to Mitutoyo or Starrett brands from an actual dealer.
Yep, absolutely agree - two best brands out there... Love using their stuff.
I'm pretty sure MX are mitutoyo designs in some kind of on sale or licence arrangement.
I had a set of 25-150mm MX micrometers informally calibrated when I worked at the National measurement institute of Australia and they were pretty good.
