LS rear bottom headbolt hole has hole into bell housing threads
I was assembling an aluminum gen 4 ls block and i noticed this when i was checking ring gap. Will this be fine or should i scrap the block? The bolt comes from a bolt hole for the bell housing and Im assuming it was my fault when i put it on the engine stand but again this is my first build.
