EGT on Motec for 10 Cylinder
MoTeC M1 Software Tutorial
I need to put EGT on my Lamborghini. What are people using with a V10 to do in cylinder EGT?
I would assume you have the M1 plugin kit since this is posted in the M1 software category? Two MoTeC E888s, they have to be configured to use the alternate 50hz transmit IDs and wired to CAN1 of the master ECU and CAN3 of the slave ECU
