MoTeC long term fuel trim
MoTeC M1 Software Tutorial
Hello,
Can someone give us context on the functionality of Motec closed loop trim and on what basis these would be adjusted?
Thanks
Hi,
The Fuel Closed Loop Control Trim Average is the percentage correction step that the FCL system will take for each update (based on the Fuel Closed Loop Period setting) that it does, a smaller number here will reduce the rate of update changes made.
Thanks for the insight Stephen.
So would that mean the gain value here would affect the frequency of the updates (in a way, as it would apply trim on the FCL period?)
or is it modifying the main FCL control trim?
Thanks
It affects how much trim is applied at each update, with the update coming from the Period table.
