Using Aim Dash to output Haltech I/O CAN
MoTeC M1 Software Tutorial
Hello,
I needed some help converting the raw Haltech CAN formula (y= X*5/4095) to AIM formula format (output VALUE = (a * Channel) + b). Can anyone help?
I figured out the CAN ID, 29 bits, 8 bytes, Big Endian, 50hz frequency. Any recommendations welcome.
Here is the Haltech IO expanded CAN example for AVI1
AiM Software
So you are trying to send AiM data to the Haltech? I would just use the multiplier on your last screenshot set to 4095 / 5 (which is 819).
This worked great David, Thank you!! I tried so many combos last night and it was that simple.
Thanks again!
