Data Log Bosch ME2.1
Practical Standalone Tuning
What is a good solution to data log a Bosch M2.1 in a SLK230?
I have tried using my HP Tuners MPVI2, but no matter the sample rate, it samples data every few seconds. I have also used my scan tool, Launch CRP123, but it does not allow you to export the log file.
Any suggestions would be appreciated.
Try the vehical logger. You need a tactrix open port cable for it.
Thanks for the tip. I'll check it out.
Vehicle logger didnt work.
What I found to work was using the Torque Pro app with a wi-fi code reader. Amazon.com: Foseal OBD2 Scanner, WiFi Car Code Reader Check Engine Light Diagnostic Scan Tool for iOS and Android : Automotive
Another combination that worked was using the Tactrix Openport 2.0 knock-off; J2534 drivers and ScanXL software from Palmer Performance. Home - Palmer Performance Engineering, Inc.
Also, the inexpensive wi-fi code reader works with the Palmer software.
