fuel tunning
Practical Standalone Tuning
when im tunning the fuel table in the motec m1 serious if i set the numbers all to 50 is the computer going to quickly make the calculations when im driving by steady state in other words in steady speed or rpm is it going to figure out automitically the calculations needed to put in after i have configured the target air fuel ratio table lambda which is around 1 or i need to do it myself the fuel table ??manually calculate the fuel for each rpm multibly it by 5 percent or less if it is not nearly my target air fuel ratio which is lambda 1.000 ???
thank you
With the M1 Efficiency Table, and the Fuel Mixture Aim correctly set, you can just get on site and press the Q key to adjust to the target mixture then press the return key to apply that change.
You can learn about this in M1 Tune, under Help->M1 Tune User Manual Search for "Quick Lambda Function".
Note that you can also do this with recorded data (ie, you paused using the T key, then scroll back, and use Q on the cells that are not matching your target mixture.
Have you watched the worked example at the end of the course on the M1 platform? This shows the various ways that you can make changes to the fuel delivery via the efficiency table in the M1.
