Idle control
Practical Standalone Tuning
Relevant Module: Worked Examples > MaxxECU > Step 6: Idle Tuning
Hi,
I'm running egas and I don't really know how to adjust the idle in maxxecu. It's set to closed loop and my idle control is at 2% and max 10%. I assume PID is where you adjust if it sways for example.
Have you looked at the help for E-throttle idle tuning found here:
https://www.maxxecu.com/webhelp/settings-ethrottle.html
Since MaxxECU is from Sweden, it should be easy for you to contact support if you need more help:
https://www.maxxecu.com/contact/
