Clearance
Practical Engine Building
Relevant Module: Worked Examples > Toyota 2JZ > Step 7: Short Block Assembly
If u have more piston to bore clearance will engine not burn excessive oil
Yes, it will, as well as excesive fuel comsuption, howewer if it is not too far of and you are ok with little bit more consumption, it is still better than ruining the honed pattern of block by having too little clearance.
