Bosch 0281006028 MAP sensor 3 bar calibration Tuner Studio.
MoTeC M1 Software Tutorial
Dear Colleagues! I am installing Bosch 3 bar 0281006028 MAP sensor to Stealth PCM which is plug and play PCM for JZX90 1JZ-GTE, replacing factory map sensor, PIM pin of ECU.
Do i need to make some calibration for it? Maybe someone have a voltage/pressure curve for this sensor?
Best regards,
Alex
