Hardware
Practical Standalone Tuning
Relevant Module: HPA 10 Step Process > Step 1: ECU Configuration and Testing > ECU Configuration
What type of hardware should I buy to tune LS ECU
I have tuned several stock GM LS ECUs using HP Tuners MPVI interface. The latest version is MPVI V4. I would get that, and explore their forums for information about different ECU versions.
I just realized you posted in the Standalone Tuning section. Are you asking what standalone ECU (MoTeC, LinkECU, MaxxECU, etc) you should select to run an LS engine (if not the stock one)?
